macnavi
#1 Posted : Monday, September 21, 2015 1:57:15 PM(UTC)
macnavi
Netherlands
After running Powerpack->Mesh Tools->Mesh Analysis, I selected my complete model and it went on analysing every single mesh. As I realised what I had done, it would take an hour to click OK on every window that appeared. There is no cancel button on that window to stop the action. Esc doesn't work, neither does command-dot. Is there another way than force quitting the app to stop this?
If not: there is enough space for a cancel button on the bottom of the pop-up window.
#2 Posted : Monday, September 21, 2015 3:02:28 PM(UTC)
I've been adding a "Press ESC to Abort" to tools that take long to process. This is in the next PowerPack build.
macnavi on 9/21/2015(UTC)
macnavi
#3 Posted : Monday, September 21, 2015 3:57:34 PM(UTC)
macnavi
Netherlands
Excellent!
