horst.w
#1 Posted : Friday, September 18, 2015 2:15:02 AM(UTC)
horst.w
Hi @ all,
I'm using VIACAD 9 Pro -german version - and I have trouble when creating a wineglass following the advices in the tutorials (video and book)
Beginning with the strait single lines, following with the splines, has no effects when I use the rotation-tool.
[img=UserPostedImage]NotPlanar[/img]
Ok, therefor I must close all gabs with the edge-tool, but when doing this, the main-single line ist not longer a axis for the rotating-tool and -very important- all lines are now splines. the right angle of the strait single lines are mutate to a rounded curve.
[img=UserPostedImage]Rounded edge[/img]
It neads now a new axis like a helpline or single line, but positioned on the origine cause a failure"Self-Intersection" and it needs to move the axis outside a little bit.
Now using the rotating-tool I habe a volume object that needs to be hollow.
But using this tool is not possible, because the program will find an open face
[img=UserPostedImage]OpenFaces[/img]
Caused by the rounded edges between the single lines in the top plane is a Black Hole
[img=UserPostedImage]BlackHole[/img]
The only one solution I have found with a negativ form of the spline curve of the outsite of the glass, and cut out this from a right angled plan. But that is not the true way for a construction.
What can I do?
Horst.w
GER
Antoine
#2 Posted : Friday, September 18, 2015 3:29:21 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
Hello,
The most important modeling in Shark: Always activate snap: PLAN when you draw mode: view from above, right, front, etc.
AND .... always disable the snap PLAN when you draw in perspective mode.
If you do not, there is a good chance that your section composed of your splines, are not coplanar.
See plz my video for explanation:
http://www.screencast.com/t/Dy6fmWOYL
Antoine
Edited by user Friday, September 18, 2015 3:35:01 AM(UTC)  | Reason: Not specified
horst.w
#3 Posted : Friday, September 18, 2015 6:09:05 AM(UTC)
horst.w
but trying this, I had no success.
When I began in 2014 with ViaCAD I trained the drawing by repeating all tutorial and manuals and videos on YT there where no difficults. The issues occures the last 5 or 6 weeks and I have no idea what happens.
Following the wineglass-tutorial step by step, there is the first difference in using the rotation-tool. The tutorial shows a mouseclick on the axis with it and the volume body is compleat. I earn only a message, that the curves are not closed ... When I close them, all lines mutate to spline and all edges are rounded and the axis does not work. Why that ??? All toleraces-settings are zero.
Also I can not delete the Black Hole than the whole object and because this hole exists, I can not make hollow the volume body.
I tried also a simular wineglass drawed only with single lines, put them to a closed curve and all is well done. There is no Black Hole and the Solid-To-Shell is working as expected. The fault must be hidden in the function of the spline-curve.
sincerly
Horst
Antoine
#4 Posted : Friday, September 18, 2015 7:45:38 AM(UTC)
Antoine
Switzerland
please, send your model for investigation.
Thank you
horst.w
#5 Posted : Friday, September 18, 2015 12:34:41 PM(UTC)
horst.w
Antoine,
many thanks for your efforts!
Step 1 to 4 is the repeating of the tutorial step by step, draw in 2D-mode and than switched to 3D
Step 5 is the trying to follow the tutorial with the rotating-tool, but no success; message: curve open
UserPostedImage
Step 6 is the closing of the curves and it looks like this:
UserPostedImage The edges before closing curves
UserPostedImage The edges after closing curves
Horst
Edited by user Friday, September 18, 2015 12:39:46 PM(UTC)  | Reason: Not specified
Step1To4.vcp (17kb) downloaded 9 time(s).
Step5To6.vcp (38kb) downloaded 9 time(s).
#6 Posted : Friday, September 18, 2015 2:41:44 PM(UTC)
Horst
The message you first received was the curves were not planar. Meaning it thought that point in the curves were not all on the same plane x-y. It didn't say anything about open profiles or gaps so i would not do step 6. I would check curves in inspector and see if any have endpoints with z values.
horst.w
#7 Posted : Friday, September 18, 2015 4:18:00 PM(UTC)
horst.w
Definitiv Z = zero for all lines; following the tutorial I draw in the 2D-mode but try it also in the 3D-mode with the same result: Z = 0
Besides that a rotating objekt only drawn with single lines or multiple lines is ok and can be hollow.
In the meanewhile I have testet all other spline-curves with the same result. All rotated objects had a Black Hole in die center.
Greetings
Horst
#8 Posted : Friday, September 18, 2015 9:55:42 PM(UTC)
Hello Horst
In the step 1 to 4, the profile lathed fine for me.
In the step 5 to 6 file the centerline is part of spline. This should be a line as in the example below.
Edited by user Friday, September 18, 2015 9:59:40 PM(UTC)  | Reason: Not specified
horst.w
#9 Posted : Saturday, September 19, 2015 2:22:24 AM(UTC)
horst.w
Hi Tim,
the examples below are where?
But that isn't the problem. I can use a single line or a help-line, that's going well. But the rounded egdes make the problems. It is not possible to deposit this axis-line as near as necessary to avoid the Black Hole; either I have a distance and a Black Hole or I have a self-intersection. My pictures show a grid-line in the background, that are millimeter-grid of the workplane. We are speaking about a 0,05 mm distance.
Is it normal, that the strait single lines mutate to a spline when using the curve-together-tool, when one curve is a spline and the others are single- or mutiple-lines?
And why mutate the rectangular edges between 2 or more single-lines to rounded edges when at the end a spline-curve is coupled.
Is it possible, that the english version is different to the german version?
Sincerly
Horst
Edited by user Saturday, September 19, 2015 2:25:04 AM(UTC)  | Reason: Not specified
#10 Posted : Saturday, September 19, 2015 5:31:56 AM(UTC)
Sincerly
Horst
Horst
The file you posted steps1-4 works when I use the lathe tool in build 1168. The connect curve tool is working as the tool is intended. It is not intended to connect 2 lines by just extending the existing lines. You should not have to use this tool in this example. The issue getting the curves to work as in your file steps1-4.vcp
If you cannot get the file steps1-4 to work what error do you get?
What build are you using? Are you on a pc or mac?
horst.w
#11 Posted : Saturday, September 19, 2015 1:16:04 PM(UTC)
horst.w
Some month ago there was an update only for the english version; therefore the last build for the german version is 9.0.4 Build 1166, updated I believe 6 - 8 weeks ago.
PC - Windows 7 Prof, 64 bit
When you can use the lathe tool after the first 4 steps of my drawing (only draw in 2D-mode the 3 single lines and the contour-spline, end-point to end-point), than there is the first issue on my softwareinstallation.
If I do this (as step 5), there is the following fault message: "Curves are not planar" and I can do none other than couple the lines and the spline with the well known consequences, > rounded edges > Black Hole > no hollowing possible. All the other tools (solids and surface) are without funktion as long as I do not couple the lines/spline.
When I draw only with single- or multible lines, all funktions are normal as expected.
My next step will be reinstalling the programm from cd.
Many thanks for your support
Horst
horst.w
#12 Posted : Sunday, September 20, 2015 12:04:04 PM(UTC)
horst.w
Hi @ all
after re-installing of the programm and setting the highest resolution all functions are well. The problem seems to be solved.
Also many thanks to Timm - member treinisch ; http://forum.punchcad.co...sts&t=7414#post27656 - for his email-support.
Horst
Ffdsagf
#13 Posted : Wednesday, October 21, 2015 9:20:12 PM(UTC)
Ffdsagf
It didn't say anything about open profiles casesam.co.uk or gaps so i would not do step 6. I would check curves in inspector and see Samsung Galaxy S6 cover if any have endpoints with z values.
Edited by user Thursday, October 22, 2015 8:23:25 PM(UTC)  | Reason: Not specified
Guest (10)
