querious
#1 Posted : Friday, September 18, 2015 11:16:53 AM(UTC)
querious
Please excuse if posted in wrong place, but I can't see anywhere else for bug reports.
ViaCAD Pro V9.0.4 (build 1166)
If I group 2 or more 3D objects, it is impossible to use selection to grab any part of the group to move it. Is this known and is there a fix?
In general, although I appreciate the features of V9, it feels much clunkier than V8, is there any way back to V8 until V9 matures?
#2 Posted : Friday, September 18, 2015 11:25:32 AM(UTC)
Are you using Mac or PC?
#3 Posted : Friday, September 18, 2015 1:23:38 PM(UTC)
Hello
Could you possibly have locked the items or group. Select unlock and then select the objects and see it they are then select-able
If its locked you will not be able to select.
Can you just create 2 quick 3d objects and group and post the file?
querious
#4 Posted : Monday, September 21, 2015 1:54:29 PM(UTC)
querious
Thanks Tim & jdi000
I'm running Mac version. ...and I've checked again. If I group two simple 3D objects and check that they aren't locked :-) , they can be moved with the triad thingy, but I can't grab the grouped object by itself to move it :-(
Couldn't work out how to upload a file to this forum (my bad) so here's a link to a simple file with two objects requested by jdi000:
http://www.digitalmedialab.net/viacad/Test.vcp
Thanks if you can help.
#5 Posted : Monday, September 21, 2015 2:39:55 PM(UTC)
Hello
Are your snaps turned off?
querious
#6 Posted : Tuesday, September 22, 2015 9:05:02 AM(UTC)
querious
Hello
Thanx Jason for the pointer to checking if snaps turned on, but was turned on. However, you've hit the nail on the head about what my problem is: group 2 3D objects together and the snaps don't work, ungroup them and the snaps will work again.
I also went back to V8 and tried creating 2 object and when grouped snaps work fine. Save the doc and open in V9 and snaps won't work on group, ungroup an it does and as a check go back and open again in V8 and all is still working there.
Maybe I'm being thick, but it looks like a bug - is there somewhere special for reporting suspected bugs?
defkon
#7 Posted : Wednesday, September 23, 2015 6:09:35 AM(UTC)
defkon
Hi
I can also reconstruct the error, see the two movies in the attachment.
In Version Pro9 V 1104 it is ok,
but in V 1066 you can find the error.
Also you can't see the complete gripper if you don't activate wireframe.
Is there also a solution to change thickness of the edges from object?
In 1104 its thinner as in 1066
Pro9v1104.mp4 (817kb) downloaded 16 time(s).
Pro91066.mp4 (1,050kb) downloaded 10 time(s).
#8 Posted : Wednesday, September 23, 2015 1:14:13 PM(UTC)
Try turning on "Aways Visible" in the Inspector.
defkon
#9 Posted : Wednesday, September 23, 2015 3:08:06 PM(UTC)
defkon
Hi Tim,
ok thanks
Matthias
