Hello Ending a CNC project with ViaCAD 2d/3D, the 3D design is achieved I am now to export to QCAD and to CamBam, in DXF, mainly for cutting frame parts, mainly for converting faces in 2D. I isolated parts of 3D model to prepare machining of different elements. I tried to Export to DXF but I am getting Error (as described in another post on this forum). The updated build 1166 works well but in English and of course only for 14 days (4 days remaining for me)and I use it to export my job in DXF. Is build 1166 french version coming soon ? (usable with my Viacad9 build 1125 licence) or is there any correcting patch for that DXF export not working, I am rather stopped in my work due to that. Thanks for your reply. Best Regards Jean Paul Béhague ps: except that problem, I am very satisfied with ViaCad 2d/3d ,fine and easy to use !
Hello Jean Paul Checking…..Are you using Mac or Windows ViaCAD 9? Regards Tim
Hello Tim I am using Windows 10 with ViaCAD 9 build 1125 Regards Jean-Paul
Hello Back to forum Still trying to get dxf export working. Thanks.
Hi Tim I have the chance to use 3 PC for design, so I installed, as a last option, "limited to 14 days version 1166" to the third PC to finish my job and to export my jobs to DXF. But now, I can use DXF export only for 13 days , after that, ViaCAD 9 build 1125 french version will be unusable for me as I am using dxf files in the last step before machining. Reading that forum, I saw that I am not the only user with that trouble ! Is there any luck to get a 1166 french version, or a patch to correct bug in dwg/dxf export on french version. I was close to lost 3 weeks of ViaCAD session... du to french version dxf export not working. Best regards, hoping for a solution. Jean Paul
Hello Jean Paul I'll make you a ViaCAD 2D3D FR build tonight and send via private email. Regards Tim
Jean Paul I sent you a link via email to ViaCAD 2D3D FR 1170 beta. Please let me know if that corrects the issue. Tim
Hello Tim Thanks a lot I will test and inform you. Regards Jean Paul
Hello Tim I have just tested 1170 beta in french and DXF export is ok now, fine !. Thanks a lot Tim And I will continue to enjoy that soft !. Cheerio Jean Paul
>> I have just tested 1170 beta in french and DXF export is ok now, fine !. Excellent. I sent the 1170 French build over to Encore Tech Support should anyone else come across the problem. Tim
