MaiFy
#1 Posted : Monday, September 14, 2015 6:01:57 PM(UTC)
MaiFy
I have had shark for a few years but it is only lately I have started to get into some the features and capabilities.
I like it and it is a very useful program with a lot of depth.
One issue that I am having is copying and pasting between drawings. It works fine except when you close a file and reopen it, the initial paste is messed in with where it has been moved to.
Does anyone else have this problem, Is there a solution or is there a patch available?
Another thing that I have trouble with is the hatching tool.
It comes up often with the message, Valid hatch region not found.
You can try a few times and often it will take the hatch.
Other times it requires retracing over the area and again it may or may not take making it necessary to break into squares, all the extra drawing is time consuming, Is there some trick to making this work reliably?
Any tips appreciated
I am using build 1028
and Shark FX V8
Thanking you
Mark
Double paste.JPG (77kb) downloaded 14 time(s).
