FredBMC
#1 Posted : Friday, September 4, 2015 9:15:20 AM(UTC)
FredBMC
Hello,
I have an error with ViaCAD9 on Mac.
I can not export my file DXF / DWG.
Here is the screenshot.
FredBMC attached the following image(s):
#2 Posted : Friday, September 4, 2015 9:23:16 AM(UTC)
What is the build version? The build version is displayed in the splash screen.
Is this from the Mac App Store? I want to try and repeat using the same build.
TIm
Edited by user Friday, September 4, 2015 9:24:15 AM(UTC)  | Reason: Not specified
FredBMC
#3 Posted : Friday, September 4, 2015 9:33:14 AM(UTC)
FredBMC
Thank you Tim.
Here is my setup :
My ViaCad : v9.0.0 Build(1125) (French version)
My Os : Mac Os X.10.5
My Computer : MacBook Pro (Retina, 15 ", end 2013, 2.3 Ghz, 16 Go)
I have purchased my software at http://www.lgandco.fr
#4 Posted : Friday, September 4, 2015 9:58:03 AM(UTC)
I would first like to see if getting a current build corrects the problem. I will see if I can make a 1168 French build and send you links via email. Hopefully by Monday.
>>Mac Os X.10.5
10.10.5?
Edited by user Friday, September 4, 2015 10:00:05 AM(UTC)  | Reason: Not specified
FredBMC
#5 Posted : Friday, September 4, 2015 10:06:58 AM(UTC)
FredBMC
I tried the version (1166) and export work.
But my activation key is not working.
I can just try for 14 days.
FredBMC
#6 Posted : Friday, September 4, 2015 10:08:21 AM(UTC)
FredBMC
>>Mac Os X.10.5
10.10.5?
Yes
FredBMC
#7 Posted : Friday, September 4, 2015 12:33:14 PM(UTC)
FredBMC
How to get a French version that works with my SN?
#8 Posted : Friday, September 4, 2015 2:15:09 PM(UTC)
I will need to check with Encore as they add the SN. In the meantime, I will send you a solution Monday to try.
FredBMC
#9 Posted : Friday, September 4, 2015 9:59:38 PM(UTC)
FredBMC
Thank you Tim
FredBMC
#10 Posted : Monday, September 7, 2015 3:09:50 AM(UTC)
FredBMC
Hello Tim.
Have you some news for me ?
#11 Posted : Tuesday, September 8, 2015 2:17:16 AM(UTC)
Yes, build 1168 French was sent via private email. If you can confirm this corrects the issue that would be great.
