Hello,
I have an error with ViaCAD9 on Mac.
I can not export my file DXF / DWG.
Here is the screenshot.
FredBMC attached the following image(s):
(390kb) downloaded 22 time(s). You cannot view/download attachments. Try to login or register.
What is the build version? The build version is displayed in the splash screen.
Is this from the Mac App Store? I want to try and repeat using the same build.
TIm
Edited by user Friday, September 4, 2015 9:24:15 AM(UTC)
Thank you Tim.
Here is my setup :
My ViaCad : v9.0.0 Build(1125) (French version)
My Os : Mac Os X.10.5
My Computer : MacBook Pro (Retina, 15 ", end 2013, 2.3 Ghz, 16 Go)
I have purchased my software at
http://www.lgandco.fr
I would first like to see if getting a current build corrects the problem. I will see if I can make a 1168 French build and send you links via email. Hopefully by Monday.
>>Mac Os X.10.5
10.10.5?
Edited by user Friday, September 4, 2015 10:00:05 AM(UTC)
I tried the version (1166) and export work. But my activation key is not working. I can just try for 14 days.
Originally Posted by: Tim Olson >>Mac Os X.10.5 10.10.5?
Yes
How to get a French version that works with my SN?
Originally Posted by: FredBMC How to get a French version that works with my SN?
I will need to check with Encore as they add the SN. In the meantime, I will send you a solution Monday to try.
Hello Tim. Have you some news for me ? Thanks
>>Have you some news for me ? Yes, build 1168 French was sent via private email. If you can confirm this corrects the issue that would be great. Tim
