I´m trying to create a rotation-solid by applying the lathe tool to this bezier curve:
and reproducibly get this result:
Even when using the other spline options.
Does anybody now whats going on?
Kind regards
Timm
P.S. I´m using the Mac version of ViaCAD 9.0.0 Build 1103 - Evaluation Copy
Edited by user Tuesday, August 25, 2015 12:41:09 PM(UTC)
>> ViaCAD 9.0.0 Build 1103 - Evaluation Copy Can you post the profile? I want see if that is happening in the current build. If not, I'll get you a current trial using 1166. Thanks Tim
Hi Tim,
here is the ViaCAD file. Its not the original one, but the effect occurs every time I draw a profile with this specific appearance. Probably I´m doing something wrong during creation of the profile?
Anyway: here is the file:
http://privatfrickler.de...lterbecher_bug.vc3_1.zip kind regards
Timm
The facetting in 1103 is not meshing the part correctly. If you change resolution, it should correct. I'll send you links to the 1166 trial via private message.
Edited by user Tuesday, August 25, 2015 4:15:58 PM(UTC)
Hi Tim. yes do so pls. Indeed changing the resolution helps. Kind regards Timm
Hi, I downloaded the new version, works like a charm! kind regards Timm
Excellent. I've contacted Encore and reminded them to replace those old trials. Several hundred issues have been addressed between 1103 and 1166. Regards Tim
