Mikevos
#1 Posted : Monday, August 10, 2015 3:44:41 PM(UTC)
Mikevos
I have a sphere and would like to project text to the surface. Is there any trick. I tried the tool tips. looked at a couple of videos but it does not work.
I select the "project curve surface" tool
I can select the text.
click on the sphere surface.
Then it asks for 2 points. I tried clicking all over - nothing seems to work at all. no projection whatsoever.
what am I missing here?
thanks
Mike
#2 Posted : Wednesday, August 12, 2015 6:08:04 AM(UTC)
thanks
Mike
Hello Mike
Try this in the following order
Create your sphere
Create an arc on the sphere
Use the text along path to create text on the arc
Then use edit change object type - convert to curves
Then use the project curve surface tool to project the text curves onto the sphere
Mikevos
#3 Posted : Sunday, August 16, 2015 6:49:06 AM(UTC)
Mikevos
Thank you. With the help and trying some workarounds I got the result eventually.
I think the capability I saw maybe from SharkFX and not from ViaCad Pro. but with a couple of extra steps I got to the required result.
regards
Mike
Jean-Francois Jacques
#4 Posted : Monday, August 17, 2015 9:14:43 AM(UTC)
Canada
Along Curve Text is very buggy!
My pix is just an example..
Jean-Francois Jacques attached the following image(s):
Screen Shot 2015-08-17 at 11.13.13.png (79kb) downloaded 17 time(s).
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
