Suggestions
Random solid sticks to mouse after adjusting size
Thanks: 13 times Was thanked: 13 time(s) in 10 post(s)
Reproducing issue: 1) Create a solid. 2) Keep solid selected, do not deselect. 3) Adjust length (or width or height) immediately in the boxes in the adjustment bar on the top. 4) Press enter 5) Now the mouse will click once by itself. If you hit a short cut to get the mouse arrow, it will select an object that is just under your mouse when this bug appear. The object will stick to the mouse. If you moved instead over a toolbar item, it will select the toolbar item. You can then not hit ESC to cancel this unwanted action, but have to click to confirm, then undo. This bug is reproducible most of the times, on both of my MacBooks with ViaCad build 1152. Only one of them has a Logitech mouse attached.
It's not only a solid sticking. The mouse is clicking by itself after 2 seconds of entering a number in the field, so it will perform a click action with the tool selected at that moment. If you got the blend tool selected, it will blend whatever first item it touches. This behaviour is very, very annoying. Running Mac OS X 10.10.3.
I believe this is related to 10.10.3 and greater. Looking into. Tim
Same issue reported by others in Beta section of this forum:
http://forum.punchcad.com/default.aspx?g=posts&m=27516 Edited by user Thursday, July 30, 2015 8:24:18 AM(UTC)
| Reason: URL adjusted
Suggestions
