Art Smith
#1 Posted : Thursday, July 23, 2015 3:52:26 PM(UTC)
Art Smith
attempting to create a 3D surface from a close curve made from jointing two splines & an arc and a third spline. after selecting both curves I'm getting an ACIS error message that says "wires must either be all closed or all open". any thoughts on what it means and how to avoid it would be greatly appreciated !! the attached image shows the reasonably simple nature of the geometry I'm attempting to learn with.............
Art Smith
artesmith@earthlink.net
Edited by user Thursday, July 23, 2015 3:54:10 PM(UTC)  | Reason: Not specified
skin surface tool opportunity 07-23-2015.jpg (85kb) downloaded 14 time(s).
#2 Posted : Thursday, July 23, 2015 4:58:36 PM(UTC)
Was thanked: 523 time(s) in 358 post(s)
Hi Art
I think one of the sections is closed and the other is not. Typically for a skin surface your sections will be all closed or all open. If you post the file I can check further.
Edited by user Thursday, July 23, 2015 5:27:00 PM(UTC)  | Reason: Not specified
