dougw
#1 Posted : Tuesday, July 21, 2015 3:15:02 PM(UTC)
dougw
Made a model with three layers. Layer one is a pipe. Layer two and three are both
flanges added to the pipe.
Doing a model to sheet I have a couple issues.
1. My top right view port displays an isometric view but wire-frame. I'd like to have it
display a solid.
2. If I try to modify the view in any way I lose my pipe. The flanges stay but
the pipe disappears. The more I mess with modifying the view the more likely I
am to lose one of the flanges too.
Any help appreciated.
All the Best,
Dougw
dougw
#2 Posted : Tuesday, July 21, 2015 3:40:09 PM(UTC)
dougw
Fixed.
When creating a model to sheet you need to set the "Edges" in
the properties window to Flatten, Phong, or Gouraud. This
gives you a solid in each viewport.
You can then select a viewport, right click and select properties
then change the "Edges" setting to "Poly-lines" to get a wireframe
in that viewport, if desired.
Changing a viewport to Flatten, Phong, or Gouraud after originally
selecting "Poly-lines" doesn't seem to work.
Bet I spent 3 hours fooling with this before my original post.
All the Best,
dougw
Edited by user Tuesday, July 21, 2015 3:42:47 PM(UTC)  | Reason: Not specified
#3 Posted : Wednesday, July 22, 2015 10:51:17 AM(UTC)
Hi Doug
FYI, I've got a video that gives a general overview of the model to sheet tool at:
Creating 2D Drawings from 3D
http://www.masterviacad.com/page7/page58/page58.html
dougw on 7/22/2015(UTC)
dougw
#4 Posted : Wednesday, July 22, 2015 3:41:59 PM(UTC)
dougw
Thanks Tim.
All the Best,
dougw
Edited by user Wednesday, July 22, 2015 3:56:04 PM(UTC)  | Reason: Not specified
dougw
#5 Posted : Wednesday, July 22, 2015 5:58:39 PM(UTC)
dougw
I can't get a hard copy print when I have a rendering in a viewport.
If I do a poly-lines wireframe it prints just fine.
