Pobble
#1 Posted : Sunday, July 19, 2015 3:55:07 AM(UTC)
Pobble
Viacad 2D3D V9.02 Build 1163
I have just drawn a rectangle and want to fill it.
Selected the fill icon and when I click in the rectangle I get the error message 'Valid hatch region not found'.
Any ideas why?
Brian
#2 Posted : Sunday, July 19, 2015 7:15:17 PM(UTC)
Brian
If the closed object is not a single entity like a smart polygon or a group it can't be filled with single click, unless all the lines are selected first. After selecting the fill tool, if you hit shift and draw a window around say 4 lines shaped as a rectangle, and they are closed then it would fill.
MaiFy
#3 Posted : Monday, July 20, 2015 2:06:09 AM(UTC)
MaiFy
Hi Pobble
I often have trouble with the hatch tool.
Some times it works and sometimes I just keep redrawing areas until it decides to take.
Pobble
#4 Posted : Monday, July 20, 2015 5:50:30 AM(UTC)
Pobble
Thanks for the help.
I have found that it is a bit hit and miss.
I drew a single line diagonal polygon, not smart one, and then grouped it.
I could not then get it to fill.
I then drew a circle and filled that and found that if I clicked on my polygon it wuld fill ok.
Don't you just love inconsistancies!
Smart rectangles seem to work all the time so I will stay with those.
Brian
