Pobble
#1 Posted : Sunday, July 19, 2015 3:15:00 AM(UTC)
Pobble
New to Viacad 2D3D V9.04 Build 1163 and having a couple of basic issues.
I have drawn a 2d box. The manual says a double click on an object will bring up a dialog box of the object's data.
When I double click on the 2D box nothing happens.
If I select the box by Click, hold and move right to left, and look at the Inspector I have no data tab onl;y Attributes, so cannot change the size etc.
Any ides what I am doing wrong?
Thanks Brian
rokoko
#2 Posted : Sunday, July 19, 2015 4:52:25 AM(UTC)
rokoko
if you draw a polygon, there are two options: single line and smart polygon. try this
Pobble
#3 Posted : Sunday, July 19, 2015 2:43:22 PM(UTC)
Pobble
Thanks Rococo
That sorted out the filling issues and also the data tab.
However I still get nothing when double clicking as the manual says.
Brian
rokoko
#4 Posted : Sunday, July 19, 2015 2:53:42 PM(UTC)
rokoko
hi, double click on an object is unused afaik. you can double click inside the concept explorer -> features tab if objects are selected
#5 Posted : Sunday, July 19, 2015 7:10:35 PM(UTC)
Originally Posted by: Pobble Go to Quoted Post
... get nothing when double clicking as the manual says.
Brian
Brian
If the inspector is closed, doubling clicking on a single object open the inspector to the data tab so it can be modified easily. This also works on individual features of 3d objects, for example if you had a rectangular plate with corner radius or holes you could double click on the feature to open the inspect data tab for that individual feature vs finding it in the concept explorer and opening from there.
Pobble
#6 Posted : Monday, July 20, 2015 5:57:15 AM(UTC)
Pobble
Thanks for the replies.
I think I now understand it.
Apologies but it is a steep learning curve at the moment.
Brian
