                Hi, I just downloaded viacad pro 9 from Ap store. the default language is set to French or polish. I don't know both of the languages, unfortunately. can some one help change the language to English?
                Hi Naser I''ll put together some instructions/tip in the next day or two.  It requires access to an English build(trial or beta) plus moving files around manually.  You can also contact Encore support and they might be able to swap out the Mac App Store build with a non mac app store English build. Tim
    Tim Olson  IMSI Design/Encore
                thanks. looking forward to it
Thanks: 13 times Was thanked: 13 time(s) in 10 post(s)
                With any normal app, you can actually use this very handy and free App Language Chooser:
https://itunes.apple.com...451732904?l=en&mt=12 Just open it, drop the application you want to run on the window and choose temporary or default change. But the official ViaCad version I tried the last time, opens strangely (closes, then opens again), so not sure if that would work. Just give it a try, it's free and might come in handy in the future again.
