Hi, you can customize the pan after clicking the middle mouse wheel and the shift key. Use sketchup pro and can not get used to this combination. I know it's a stupid request, but for me it would be very convenient if you could customize the wheel + key combination. Thanks in advance for the attention Nicola
Thanks: 13 times Was thanked: 13 time(s) in 10 post(s)
Don't you use the spacebar if you want to pan? I'm not sure if I understand your request or question. Do you want to change panning, from spacebar to middle mouse wheel and shift key??
You mean that it would be more convenient to be able to customize these things. when using more software is nice to use the same key for the same functions. I do not know if it will be possible, because the development team has more important things to do .... but if advancing a little time ... who knows? Sorry my bad english
I agree it would be nice to assign shortcuts to the mouse wheel. Currently you cannot change these settings. Tim
