Ewok
#1 Posted : Wednesday, June 3, 2015 10:07:00 AM(UTC)
Ewok
it is possible to buy PowerPackPro for ViaCad Pro V9 separately or must i buy the complete Bundle with the BetaVersion?
Maik
cnicolapc
#2 Posted : Friday, June 5, 2015 4:43:27 AM(UTC)
cnicolapc
I agree with your question, and I would add this request. For me I've already ViaCAD Pro 9, I get the 64-bit version by purchasing Powerpack LT.
I honestly do not understand this trade policy, many companies provide a single license the 64bit version and a 32 Bit.
I hope that there is an upgrade without PowerPack.
Nicola
#3 Posted : Friday, June 5, 2015 9:22:53 AM(UTC)
Hi Mark,Nicola
You can purchase PowerPack Pro as an add-on to an existing seat of ViaCAD Pro 9, Shark LT 9, and Shark FX 9 using the link below.
http://www.masterviacad.com/propromo/propromo.html
For ViaCAD Pro 9 users, you will receive a new build of ViaCAD Pro 64 with PowerPack enabled that does not time out.
Edited by user Friday, June 5, 2015 3:49:19 PM(UTC)  | Reason: Not specified
cnicolapc on 6/5/2015(UTC)
cnicolapc
#4 Posted : Friday, June 5, 2015 2:22:39 PM(UTC)
cnicolapc
Thank you for your clarification, and good work.
Nicola
Andrew Gray
#5 Posted : Friday, June 5, 2015 11:15:23 PM(UTC)
Andrew Gray
all,
i understand that you get viacad with PP purchase, is that correct
also, is the mesh to solid tool available in standard viacad?
andrew
#6 Posted : Saturday, June 6, 2015 2:03:44 AM(UTC)
Hi Andrew
If you already have ViaCAD Pro 9, Shark LT 9, or Shark FX 9 you can add powerpack pro using the link below.
If you are adding a seat or getting a new seat of ViaCAD Pro and interested in PowerPack Pro, then the promo below may be of interest.
http://www.masterviacad..../viacadpropowerpack.html
The Mesh to Analytic and SubDivision To NURB tool are part of PowerPack Pro.
