hi all, i only have a couple of days left on my trail viacad v9 with power pack im not getting any where with the program question: if a draw say a rectangle 100 x 100, extrude it then would like to change the base sketch thus changing the extrusion how do i do this?? i have rad the help and asked support iam i missing something...does viacad allow this workflow? getting frustrated with viacad..thanks all andrew
hi,
when activating wireframe mode, you can select and move the line(s) of your rectangle. your extrusion will follow this modification
Edited by user Saturday, May 30, 2015 5:54:17 AM(UTC)
(50kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Andrew Gray hi all, i only have a couple of days left on my trail viacad v9 with power pack im not getting any where with the program question: if a draw say a rectangle 100 x 100, extrude it then would like to change the base sketch thus changing the extrusion how do i do this?? i have rad the help and asked support iam i missing something...does viacad allow this workflow? getting frustrated with viacad..thanks all andrew
Hi Andrew
It depends on the sketch, and what you want to change. If you used a smart polygon you can select the rectangle in concept explorer and rt click and go to inspector attributes to change the dimensions. In concept explorer you can select the extrusion and change the length of the extrusion in the inspector.
If your rectangle is all single lines you can draw a new rectangle and use the replace curve found in concept explorer.
Edited by user Saturday, May 30, 2015 6:18:17 AM(UTC)
(12kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Hi Andrew
Below is a quick video showing how to use a polygon to drive a 3D part.
http://youtu.be/CXTQZEjmPBo Tim
Hi all
thanks for the help, i now understand to use the single polygon drop down
how about if i have a non regular shape like a steel section, cant the dims be changed
and the extrusion follow it eg similar to solidworks etc..
andrew
Edited by user Saturday, May 30, 2015 9:12:16 PM(UTC)
hi all just want to float this question back on top can non rectangle shapes be re sized? andrew
Thanks: 13 times Was thanked: 13 time(s) in 10 post(s)
Yes, you can. On a Mac, if you command-click on the vector shape, the key points will show (as well as bezier handles, if you created a shape using that). Then you can drag a box around the key point and use the Gripper to move it. The extrusion should move with it. Hope this is clear, otherwise I can make a video with it. Don't give up when you are stuck. I did gave up after my first effort, but came back to the software a few weeks later, as I really wanted to make a certain model. Start reading the manual (under the help menu), as you would read a book. It's very clear and you'll quickly find out the amazing things you can do. When you have a good start this way, then you look up the specific things you need to know. I put the pdf of the manual on my iPad and started to read it in the train to work. The only thing is that you can't wait to go home to try out your newly acquired knowledge.
macnavi, thanks for the reply, yes a video would help i come from the parametric type cad systems, so i was expecting a dimensioned sketch to change andrew
No answer in a month, its disappointing because i really want to give punchcad a go even emailed support with no answer but im not a paying customer so maybe that is why i have purchased spaceclaim and cant be any happier with it thanks all
Sorry I missed your post. Have you tried to see if you could follow my hints? I thought it was quite clear. Tech support always answers my questions within 24 hours.
Sorry I don't have the demo anymore but yes I tried to follow but was waiting for support help as well. As I said I am not a paying customer so I expect low priority which is fine I am using spaceclaim at work and DesignSpark free at home great combination Andrew
