I have sent this to Encore support but thought I would post here as well.....
I just upgraded to Shark LT v8, and performance is very poor vs the very old Concepts Unlimited v4 which I was using.
I have checked this on both a 2008 Mac pro and 2014 Mac Pro.
I generally import DWG or SAT models and generate drawings from these in Shark. These imports are not working well- I am getting hidden line generation errors.
I can import STEP without the redraw/ hidden line problems, but performance is so slow that even simple operations are too slow to be useable. Zooming with the scroll wheel takes 3 seconds to regen the screen (definitely NOT "interactive" speed)
I have sample files available.(see files attached to this post).
We have 3 Industrial Designers trying to use SharkLT, and we need to resolve this problem ASAP.
I have imported this same DWG file into v4 Concepts, and speed is not fast, but acceptable.
Thank you,
David Stoddard
Senior Designer
Profitmaster Displays
dstoddard@profitmasterdisplays.comUpdated with proper DWG and SLT files as attachments
Edited by user Tuesday, May 19, 2015 7:42:57 AM(UTC)
WireDisplay02.dwg.zip
(245kb) downloaded 3 time(s).
WireDisplay02.slt.zip
(2,703kb) downloaded 2 time(s).Arketype attached the following image(s):
(185kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
