Andrew Gray
#1 Posted : Saturday, May 16, 2015 9:52:22 PM(UTC)
Andrew Gray
hi all
i come from inventor, solidwork etc type of cad
question is, if i sketch say a rectangle at 100mm by 50mm..extrude it..then decide to change the size of the original sketch
can this be done in viacad? of do you just stretch the original sketch to suit?
also, does viacad have equations for sketches?
[tim, i need to buy your book!!]
andrew
#2 Posted : Monday, May 18, 2015 12:01:47 PM(UTC)
Hi Andrew
ViaCAD does not support dimensional constraints & equations with sketches. It does support associativity between the sketches and parts. So if you extrude a polygon (which stores length/width as part of its definition) you could go back and edit the polygon length and have the extruded shape and associated features update.
Managing and editing a complex sketch is probably a good candidate for a video. I've added that on my list for new videos for the masterviacad.com site.
Edited by user Monday, May 18, 2015 3:09:07 PM(UTC)  | Reason: Not specified
Andrew Gray
#3 Posted : Monday, May 18, 2015 2:30:40 PM(UTC)
Andrew Gray
I'll look forward to seeing the videos
Let me know when you have it up on the site.
Andrew
Edited by user Monday, May 18, 2015 4:43:03 PM(UTC)  | Reason: Not specified
Andrew Gray
#4 Posted : Thursday, May 21, 2015 12:03:21 AM(UTC)
Andrew Gray
Hi Tim
did you get a chance to make a video on how to resize skatches
thanks Andrew
