#1 Posted : Tuesday, April 21, 2015 5:03:36 PM(UTC)
also tried to register as new user and wouldn't accept many different trials for the password. I have a question concerning ViaCAD Pro 9 and need to get to the forum to ask it.
jarm22
#2 Posted : Tuesday, April 21, 2015 5:42:40 PM(UTC)
I had the forum send you a password reset. Hopefully that will fix the issue.
jarm22
#3 Posted : Wednesday, April 22, 2015 1:07:32 PM(UTC)
jarm22
Thanks, Tim.
I had tried the lost password routine it wouldn't let me get past the password screen.
Maybe you can answer a question for me.
I created a tubular shape from a cylinder and subtracted a helical shape and a slot using a rectangular shape. This created two separate pieces from the tubular shape. I don't know how to separate the two shapes. When I select either one of them, both are selected.
Jarm22
CAM SECTION 1.vcp (649kb) downloaded 8 time(s).
#4 Posted : Wednesday, April 22, 2015 3:34:53 PM(UTC)
Try the Edit : Change Object Type : Solids tool. This will separate out all the individual solids.
jarm22
#5 Posted : Thursday, April 23, 2015 10:11:02 AM(UTC)
jarm22
Thanks, Tim. That worked great. I am a novice at 3D drawing and don't use it often. I do plan to learn more and ViaCAD Pro is my choice of software. The part I am drawing is a cam section made of PVC for a powered nut cracker. I need to refine it a bit, but the basic shape is there now.
Your help is appreciated and I have watched your excellent videos several times as I explore 3D. I would really like to attend a basic class somewhere on using ViaCAD Pro and the difference between solid, NURBS, surfaces, etc. and how to work with each of them. I don't even know the technology very well at this point. As a retired Mechanical Engineer, I am proficient at 2D drawing with AutoCAD and Draftsight, but have a long way to go in 3D.
Jarm22
