NISM0
#1 Posted : Tuesday, April 21, 2015 3:44:45 AM(UTC)
NISM0
Hi
Seems Shark LT is remembering the previous value for the first time I used Shark LT polar Duplicate
its stuck with 13 in it, I clear it an enter 8, it still prints 13, then I go back to check and its reset it self back to 13, any help?
Rick
#2 Posted : Tuesday, April 21, 2015 10:21:29 AM(UTC)
Hi Rick
I seem ok here with the current build changing the Duplicates : Number field.
What build (see splash screen) and platform are you seeing this on? I'll check with tech support if they have heard of anything.
NISM0
#3 Posted : Tuesday, April 21, 2015 7:08:19 PM(UTC)
NISM0
Hi Tim
Build 1016, using mac book pro
Rick
**Edited to say I have found a way around it, If I open up Polar Duplicate it automatically remembers the old value, when I change that value the OK button becomes un-selectable, however if I am in the numbers field and press Alt/Option and 3 key adding a symbol it resets the number to what I want and the OK button becomes blue again. So there is a work around, but if you know of a fix it would be nice...thanks
Edited by user Tuesday, April 21, 2015 7:25:51 PM(UTC)  | Reason: Not specified
