Hi Guys, I have just noticed a missing feature in Concept Explorer > Symbols. In previous versions, up to v8, as the cursor is placed over individual symbol images a small title pane opened showing what the symbol is. It has been a while since I have used symbols so I was surprised to find that, in v9.0.3 Build 1146, this feature is missing. The small yellow hollow triangle feature is there but not the title label. As you can imagine this makes it very difficult to pick one screw from another. Has anyone else noticed this? Regards, Alan.
Thanks: 13 times Was thanked: 13 time(s) in 10 post(s)
You mean that when you choose Mechanical->2D Fasteners Metric Counterbore and you hover over the first image, your ViaCad will not show a yellow label "COUNTERBORE CAP 1.6F"? When I was testing this for you, it did pop up. Most of the time, though, there were some instances it didn't.
I'm using 9.0.0, built 1109
Edited by user Thursday, March 12, 2015 6:05:36 AM(UTC)
Hi macnavi, Sorry I haven't been back for a while and have just noticed your reply. You have understood my question completely. I have never seen this before in all my variations of ViaCad, even partially as you have found with your earlier v9 Build 1109. With my v9.0.3 build 1146 I have total loss of the Yellow Label, just the hollow Yellow Triangle, on all Symbol Library Images in Concept Explorer. I had rather hoped that Tim Olsen would pick up on the problem with some idea of what is going on. Thanks for trying. Regards, Alan.
There is a 9.0.5 built, try that one.
That was me again. Didn't know one could post without being logged in.
Hi, I just clicked 'Current Version' in my ViaCad v9 and was told that my v9.0.3 Build 1146 is current and no updates are necessary. I am running on iMac. Is the v9.0.5 for Windows?
Regards,
Alan
Alan B attached the following image(s):
(65kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
Please do not post product links to the public. I'll tell tech support to make sure they include that in any links they send to users. Tim
Sorry Tim, just thought it would clarify the situation. Didn't think it would be a problem amongst users.
Regards,
Alan.
Please note that the attached image is a jpeg taken from a screenshot and is not an active link.
Edited by user Saturday, March 28, 2015 7:56:07 PM(UTC)
| Reason: Further clarification.
Hi Alan Not you, someone else posted direct links to installers. I deleted the post. >>in my ViaCad v9 and was told that my v9.0.3 Build 1146 is current and no updates are necessary. I am running on iMac. Is the v9.0.5 for Windows? 1154 is currently going through Encore review for release. It will be available from the Help menu once Encore clears the update. If anyone must have a build (because of registration issues for example), they can contact Tech Support. Hopefully registration issues will no longer be a problem in 1154. Tim
Tim, can you also delete the Viagra and Cialis posts!!
