a.wieneke
#1 Posted : Monday, March 16, 2015 2:53:36 PM(UTC)
a.wieneke
hello,
i do have an .stl file and would like to work with it. what is the best way to change the object ? I tried, to change into solid, it is not working, only the beachball is running for hours.
thank you for any help
Andreas
viele Grüße
Andreas
http://www.wieneke.biz
SharkCad pro 14
OS X 14.0
#2 Posted : Monday, March 16, 2015 3:15:30 PM(UTC)
The Edit: Change Object Type uses the standard stitcher and has limits.
I am creating an add-on to ViaCAD that adds another stitcher (from IntegrityWare) and options to simplify if possible.
http://www.masterviacad....ckPro/page20/page20.html
If you can zip and send me your file, I'll see how well it works.
a.wieneke
#3 Posted : Tuesday, March 17, 2015 5:42:30 AM(UTC)
a.wieneke
thank you Tim,
how do i add the file into the post ?
Andreas
viele Grüße
Andreas
SharkCad pro 14
OS X 14.0
#4 Posted : Tuesday, March 17, 2015 9:33:20 AM(UTC)
Hello Andreas
In the lower left corner is an "Attach files to this post?" check box.
a.wieneke
#5 Posted : Tuesday, March 17, 2015 10:45:29 AM(UTC)
a.wieneke
Hello Andreas
Thank you, Tim
eichhoernchen.stl.zip (3,886kb) downloaded 7 time(s).
viele Grüße
Andreas
SharkCad pro 14
OS X 14.0
#6 Posted : Tuesday, March 17, 2015 2:21:29 PM(UTC)
Hello Andreas
Based on the organic shape of the file, I decided to use the SubD to NURB tool in PowerPack.
But since it was all unstructured triangles, I first used 3D-Coat's auto topo command to convert into quads. For a file such this, you will need to remesh.
Once converted, I was able to create a nice water tight NURB solid.
Below is a link to the resulting ViaCAD file. (99994 triangles ->63482 quads ->764 NURB face solid)
http://www.csi-concepts.com/Demo/misc/chip.zip
Edited by user Tuesday, March 17, 2015 4:14:41 PM(UTC)  | Reason: Not specified
a.wieneke on 3/18/2015(UTC)
a.wieneke
#7 Posted : Wednesday, March 18, 2015 4:08:43 AM(UTC)
a.wieneke
Hello Tim,
thank you very, very much !
one last question: could you send me the link for downloading / buying the PowerPack.
I can only find the site, where all the features are listed.
Andreas
viele Grüße
Andreas
SharkCad pro 14
OS X 14.0
#8 Posted : Saturday, March 21, 2015 12:17:58 PM(UTC)
Hi Andreas
On Friday Encore approved a variety of PowerPack Beta promotions which I should be sending out next week.
#9 Posted : Saturday, March 21, 2015 1:23:23 PM(UTC)
i will look for the Beta PowerPack
and thank you for your friendly work to change my .stl file :-)
i say good night now , here in germany.
have a nice day.
Andreas
mpix00
#10 Posted : Friday, April 3, 2015 6:28:58 AM(UTC)
mpix00
Hello Andreas
Hi Tim. I have a PNG. FILE of an image that I want to import into VIACAD. I am able to doso, but how do I attach the image onto the top of my material of 3"x3"x1.5" in VIACAD? I want to attach it to the top, then extrude the image so that I can sink it into my material, so that I can machine that image shape into my material, for example; like if I were to machine a logo in aluminum.
#11 Posted : Friday, April 3, 2015 11:00:57 AM(UTC)
ViaCAD does not have a tool that converts an image into 3D. Some possible options for you:
• Read the image into ViaCAD and trace over with curves as a basis for your 3d model
http://www.csi-concepts.com/Demo/videos/Tracing.mp4
• Try one of the free scan to dxf apps to get outlines which you can extrude
• If it is an Illustrator file, convert to paths and export as in the tutorial below
http://www.csi-concepts....tutorials/AITutorial.pdf
Good luck!
