PowerPack
Facet Orientation and SubD to NURBs
I updated the Flip One Normal tool to show surface orientation while you are in the flip command.
The orientation of facets is important when converting subdivision meshes to NURBs. In this video we use the Flip One Normal tool to identify and fix flipped normals. Once corrected we convert into a surface and thicken into a solid.
http://youtu.be/3McEMuH7JL8 Tim Olson IMSI Design/Encore
Thanks: 6 times Was thanked: 28 time(s) in 15 post(s)
Hi Tim, in 1050 the "Surface Normals Check" leaves me with a "hand cursor". I can´t select meshes.
Still the same in 1051. BUT If i combine meshes and convert them to Nurbs, it works! nice!
[ >>"Surface Normals Check" leaves me with a "hand cursor".
Fixed in 1152. This tool takes everything displayed and does not require a selection. I also updated this to a tool palette in 1152.
Edited by user Thursday, February 19, 2015 10:35:50 AM(UTC)
(33kb) downloaded 18 time(s). You cannot view/download attachments. Try to login or register.
I like the idea of having a UI for Powerpack! :-)
PowerPack
