Tobias
#1 Posted : Sunday, February 15, 2015 6:35:51 AM(UTC)
Tobias
I'm currently a little bit stuck with a problem getting correct (correctly sized) measurements into the drawing.
Here is what I try to do:
1. Create a new drawing (Ctrl + N)
2. Perform the page layout (SinglePage, Landscape, ScaleMode: Metric, Scale: 1:20, Show Printing area)
This leads to the fact, that I get a drawing area wich fits to the A4 page with a scale of 1:20. So far so good.
Now when I draw a line of, let's say 2.5 meter and I apply a measurement line, this line is way too small and the text is unreadable.
So, how can I setup the page to have a 1:20 scale, see the hole drawing area (print area A4) and still get well sized measurement lines and numbers?
Thanks in advance.
Best regards,
Tobias
rokoko
#2 Posted : Sunday, February 15, 2015 1:32:44 PM(UTC)
rokoko
hi, you can change the size of the dimensions in your drawing. select the dimension tool (no objects selected) -> go to inspector tab "dimension" and set proper size as a default setting for the drawing
