copter106
#1 Posted : Saturday, February 7, 2015 10:07:56 AM(UTC)
copter106
I'm just working through the tips and tricks doc from Tim Olson.
Now I need some help on the "How can I copy a feature with the Gripper?" exercise.
As I'm only working since a short period of time with this program, I may have only probs of understanding the technique. Or it is a bug maybe ?
What I've done / tried to do:
"Use the Deep Select tool to select the faces associated with the features you want to copy. Then, hold down a copy key and drag the faces to a new location. Upon release, the copied faces are merged into the body. "
And this not work for me. I'm always getting a ACIS Error "gap cannot be filled" followed by a "gap cannot be filled: "Face Copy_xxxx: Hint: Try suppressing feature: Extrude_xxxx" or "gap cannot be filled: "Face Copy_xxxx: Hint: Try suppressing feature: ACIS solid_xxxx"
I'm using ViaCAD 9.0.0 Build 1137.
Any kind of help would be really appreciated.
Thanks in advance
PS. I maybe wrong with this posting under "Tips and Tutorials", if so please bear with me, will make it better next time.
Edited by user Saturday, February 7, 2015 10:13:39 AM(UTC)  | Reason: Not specified
#2 Posted : Saturday, February 7, 2015 11:37:20 AM(UTC)
Hello
Can you post a pic of what your are trying to copy?
copter106
#3 Posted : Saturday, February 7, 2015 3:50:27 PM(UTC)
copter106
Hi Jason,
your question was the right question and it helped me to think about ...
I was trying to copy a complete face, containing simple holes, of one block to another block.
But I believe I understand now what it is about - I can use this technique to copy, for example, simple holes along the face of just one block.
Thanks & Regards
Mike
Edited by user Saturday, February 7, 2015 3:55:53 PM(UTC)  | Reason: Not specified
copter106 attached the following image(s):
Screenshot 2015-02-07 22.45.13.png (224kb) downloaded 14 time(s).
#4 Posted : Saturday, February 7, 2015 4:07:03 PM(UTC)
Hi Mike
Yup! It will get confused if you select the outside face as embedded feature. I added a note to this tip to better clarify.
TIm
Edited by user Saturday, February 7, 2015 4:10:35 PM(UTC)  | Reason: Not specified
