Reuben5150
#1 Posted : Friday, January 30, 2015 2:24:10 PM(UTC)
Reuben5150
Struggling with this a bit, i've completed the rest of the instrument no problem but pretty much stuck on this part, any ideas on how to approach it?
UserPostedImage
Edited by user Friday, January 30, 2015 2:25:00 PM(UTC)  | Reason: Not specified
WaveMechanic
#2 Posted : Tuesday, May 5, 2015 11:55:13 AM(UTC)
WaveMechanic
Reuben5150,
I see that your original post is about 3-months old so this may be too little too late, but I took a shot at the violin scroll. Challenging indeed, but I managed to prototype a very rough start using VIACAD 2D/3D V9. I used Interpolate Spline (see the blue, green and gray) curves in the image and then skinned them. It would obviously take some dedication to perfect the model, but here is what I came up with to get started:
Edited by user Tuesday, May 5, 2015 5:20:28 PM(UTC)  | Reason: Not specified
WaveMechanic attached the following image(s):
Tim (NOT Tim Olson)
ViaCAD 2D/3D and PRO V9 1184, Blender 2.49-2.78.
Win 7 SP1, Core I5, 64-bit, NVIDIA G105M
thanks 1 user thanked WaveMechanic for this useful post.
Brian Carter on 7/15/2015(UTC)
andreaspada
#3 Posted : Thursday, November 12, 2015 9:59:29 AM(UTC)
andreaspada
Great! I'm starting modelling some violin and cello plates, but I do not understand how to model the compound surface of the plates. Skin Surface? Sweep Rails? Any one have some clue?
Thanks!
horst.w
#4 Posted : Friday, November 13, 2015 4:32:49 PM(UTC)
horst.w
When trying some options for my projects I found another methode to realise a violin scroll.
Perhaps more easy to do but also in simple outfit.
I bent only a volume-body along a curve. The body and the curve is to optimise for a real construction.
Edited by user Friday, November 13, 2015 4:38:50 PM(UTC)  | Reason: Not specified
