jonwatts
#1 Posted : Monday, January 19, 2015 11:53:52 PM(UTC)
jonwatts
Hey all,
I'm not a Viacad user yet, but I like all that I see. My composites shop will be undergoing a gradual changeover from a craftsman's based shop to a cad/cnc based one. I'm going to start by reverse engineering some composite parts I make for various projects. The parts are not terribly complex but they do contain areas that are very organic in nature and areas that are very geometric. Based on my research, I found nothing of mention regarding any retopology tools within Viacad, so based on that assumption my proposed workflow is as follows: 1) get parts scanned 2) retopo in 3D Coat 3)import sub-d recreations to Viacad , convert to nurbs, and make my final mods before getting plugs cnc'd for molds. My questions are these. Can you open any sub-d files in Viacad given it was saved in the proper format? What format would that be? Can further modifications then be made to the imported sub-d's in Viacad?
Jon
#2 Posted : Tuesday, January 20, 2015 12:22:38 PM(UTC)
Hi Jon
//regarding any retopology tools within Viacad,
Correct, there are no retopology tools in ViaCAD or PowerPack. A scanned file without retopo is not a good candidate for subd to nurbs.
//2) retopo in 3D Coat
I've used the auto retopology tools in 3D Coat and then sent the files as OBJ to PowerPack to convert to NURBS. I was very impressed with the results. I've also tried MeshLabs but had less success then with 3D Coat.
Yes, OBJ quads are the best.
Yes but not as powerful as a dedicated SubD modeler. We will continue to add tools to manipulate subd models in service packs and new releases.
You might want to try out the ViaCAD Pro with PowerPack beta.
Online Docs & videos
http://masterviacad.com/powerpack/powerpack.html
Beta Link
http://www.punchcadlabs.com/page7/page7.php
In addition to the SubD to NURBS which is good for organic shapes, I have some work in progress for analytic shapes.
http://www.csi-concepts....deos/meshToAnalytic2.mp4
Edited by user Tuesday, January 20, 2015 12:37:20 PM(UTC)  | Reason: Not specified
jonwatts
#3 Posted : Tuesday, January 20, 2015 1:00:11 PM(UTC)
jonwatts
Ah, from the man himself! Thanks Tim for your reply, now I'm very very excited about the possibilities with Viacad but am a bit confused as to the availability of Viacad Pro with Powerpack. If I understand correctly, it's still in beta form, right? What is the price once available? Also is it possible to build part of projects in nurbs, build the organic part in sub-d's, convert them to nurbs, then merge or blend the parts together as 1 nurbs object?
Jon
#4 Posted : Tuesday, January 20, 2015 1:28:25 PM(UTC)
Yes.
There are three configurations of PowerPack (LT, Normal, Pro). PowerPack Pro MRSP is $495. For reverse engineering some tools that might interest you would be the SubD to NURBs, Mesh to Analytic, and Coordinate Compare. I use the Coordinate Compare to double check deviation between the original mesh(or point cloud) and resulting NURB (also makes sure we didn't lose critical shape as part of retopology).
There is an aggressive promotion if purchased during the beta, private email if anyone wants more information.
Yes, the tolerances used to create a part are suitable for solid modeling operations and export of the data to other applications. I've found you need to watch out for sliver triangles converted to NURBs, but if you retopo, that usually gets rid of that issue.
Edited by user Tuesday, January 20, 2015 2:13:02 PM(UTC)  | Reason: Not specified
Guest (5)
