kjellhar
#1 Posted : Tuesday, January 13, 2015 7:44:37 AM(UTC)
kjellhar
I have just installed SharkFXv9 on a MacPro which is required to live its life off line (for security reasons).
I connected the computer temporarily to the internet to perform the activation, which was successful. When I disconnected the network cable, I was back to 15 days evaluation licence. If I reconnected the network cable again, the software was activated again without having to go through the process again.
Is this how it is supposed to be?
After all, I did not change any hardware.
I did try the encore support, but the question was not in the data base, and I could not find any support form to fill out. They wrote that a form would appear at the end of the support request process, but none came.
Any help is appreciated.
Best regards,
Kjell
#2 Posted : Tuesday, January 13, 2015 10:50:13 AM(UTC)
Hello Kjell
Once activated, Shark should not need to access the internet again. Contacting tech support is a good idea, use the link below to access tech support.
http://support.encore.com/technicalsupport/tech_support_frm.aspx?product_id=2820
kjellhar
#3 Posted : Tuesday, January 13, 2015 1:50:44 PM(UTC)
kjellhar
Oh, I realize now that I didn't look for the ViaCad support form.
I'll contact them and see what happens.
Kjell
