Punch Lounge
The Press@punchsoftware addr seems dear or non forwarding (#4618)
Thanks: 76 times Was thanked: 91 time(s) in 59 post(s)
                There are some glaring typos on the VCP page. ARCHITECTURAL "Walls automatically heal when positioned next to another [walls]. Quickly explore new wall configurations by [draggin] or precisely changing parameters that control [lenght], angle, and thickness." Add intelligent wall features such as [dorrs] and windows with just a few mouse clicks. Or design a custom feature using the '[Inset] Group into Wall' tool. In VCP 7, the tool says, "Insert Group", not "Inset"... 3D DESIGN "Planar Area Properties Profesioinal feature for mechanical or [architectural] [egineers] needing precise 2D section properties." Associative Surface Modeling Create Surfaces [acciciative] to defining curves. Stitch into solids to perform feature operations. Feature Operations Intelligent features allow you to edit parts using blending, [chamfeing], holes, [basses], shelling[* needs a comma here in this series] and bending tools. Bosses, not basses.... Cheers!  VCP 7 and Shark LT v 8 user.
                Thanks! If only i discovered push pull 6 months ago using those reading skills....
Punch Lounge
