ALBANO
#1 Posted : Friday, January 2, 2015 6:41:39 AM(UTC)
ALBANO
Was thanked: 28 time(s) in 15 post(s)
I´m trying out mesh symmetry for the last days.
Found an error. Allways had the symmetry on and all seemed fine until shark got confused which vertices are the ones from the other side...
See attached picture/file....
Meshnotsymetricalanymore.sfx (40kb) downloaded 10 time(s).
ALBANO attached the following image(s):
Bildschirmfoto 2015-01-02 um 13.41.14.png (277kb) downloaded 7 time(s).
#2 Posted : Friday, January 2, 2015 7:56:11 AM(UTC)
Hi Albano,
I have converted your file to "meshes only", may be that this sheds a new light to the symmetry question
best wishes
- Bernd -
#3 Posted : Friday, January 2, 2015 7:59:37 AM(UTC)
sorry, can not attach the file.............
ALBANO
#4 Posted : Friday, January 2, 2015 2:21:53 PM(UTC)
ALBANO
Originally Posted by: Guest Go to Quoted Post
Hi Albano,
best wishes
- Bernd -
Hi Bernd,
the circles were only applied to show the questionable vertices that got mixed up.
try to manipulate them, and you will see the mirror verices on the other side are mixed up. That is: another vertex moves with the symmetry..
Thanks!
ALBAN
#5 Posted : Friday, January 9, 2015 4:14:17 PM(UTC)
Hi ALBAN
If you have the file just before it got mixed up that would be helpful for debugging.
ALBANO
#6 Posted : Friday, January 16, 2015 9:23:01 AM(UTC)
ALBANO
Hi ALBAN
Sorry, Tim. Only the file after the problem occurred.
