Delron
#1 Posted : Sunday, December 7, 2014 1:03:26 PM(UTC)
Delron
I'd like to submit a serious bug. At least for me it's serious.
If i have a closed polyline (Group) with conic and straight lines, and I attempt to offset it, the program will hang every time.
Delron
Delron attached the following image(s):
Screen Shot 2014-12-07 at 12.01.53 PM.png (12kb) downloaded 6 time(s).
rockyroad_us
#2 Posted : Sunday, December 7, 2014 4:18:51 PM(UTC)
rockyroad_us
Good find. It hangs for me after I undo and redo without grouping. It will do it without grouping first. It behaves weird with group.
#3 Posted : Monday, December 8, 2014 11:16:49 AM(UTC)
Thanks Delron, this is now fixed in the 1146+ code stream.
Delron
#4 Posted : Monday, December 8, 2014 11:38:12 AM(UTC)
Delron
Thanks Tim.
How do I get the fix? OSX.
Cheers!
Edited by user Monday, December 8, 2014 11:44:17 AM(UTC)  | Reason: More info
Delron
#5 Posted : Tuesday, December 9, 2014 11:15:17 AM(UTC)
Delron
Hi Tim,
Can you explain to me how the code stream thing works?
All I know is that you say it's fixed, but I'm still running the latest OSX version according to ViaCad.
How/When do I see the changes??
Delron
#6 Posted : Tuesday, December 9, 2014 12:31:35 PM(UTC)
Hi Delron
The code stream refers to a source code build number used by the development team. It's how we keep track of when something was fixed/changed in the source code.
Once we make a change, it might take some time to propagate out to end users as a released product. Typically it will go into beta builds first to make sure it does not break something else. If it passes through beta, then it will go into the next service pack which are released by Encore.
This correction will be in the Shark LT 9 and ViaCAD Pro 9 w/ PowerPack betas coming up later this week for testing.
