Hello everyone! I'm new to viacad and have a question. I have been practicing and getting familiar with the software at my shop on a pc. I would like to practice more at home but at home I have a mac! My question might be a stupid one but I want to ask it before I take the time to download it.. So, my question is if I save a drawing to a dxf file on my mac, will I be able to open it on my sheetcam on my pc with no problems. I would think a dxf file would be the same on either but I'm just not sure! Any advise would be good. Thanks
Edited by user Tuesday, November 18, 2014 12:56:24 AM(UTC)
Hello There will be no issues with transferring files back and forth between Mac and PC. Save as the native ViaCAD format until ready to export as dxf when needed. Regards Jason
Ok, even better! Thanks for the reply!!
Another question, viacad was on the computer I got with my CNC plasma table as a trial version. If I'm only using it to draw 2d for plasma cutting, will the 2d version of the software that is only $29 be good enough?
And if I purchase it will I be able to use it on my Mac and pc or do I have to purchase a copy for each computer?
The 2d should be fine for that The ViaCAD is a single license per pc
Ok, thanks again for the reply
Originally Posted by: Guest The 2d should be fine for that The ViaCAD is a single license per pc
actually I was told by Encore support, that I'm allowed to install / activate it on up to three computers (Macs in my case) obviously NOT to be used simultaniously, but I can have it e.g. on a laptop and a desktop machine... now if the same license / serial works for Mac and PC I can't say...
cheers Jo
ViaCAD Pro beta (PowerPack) build 1145 (ViaCAD Pro 9 build 1109) - MacBookPro 17" 10.9.5 - Thunderbolt display
ViaCAD is 1 machine install Shark is multiple pc installs I believe you were told wrong Regards Jason
Hi Jo
This afternoon Encore clarified with Tech Support the ViaCAD EULA.
With ViaCAD you can install on one machine. Shark allows multiple installs. Mac App Store uses the Apple EULA.
"1. License Grant. Licensor hereby grants to you, and you accept, a non-exclusive license to use the Software in machine-readable, object code form only (collectively referred to as the "Software"). This license does not constitute a sale and does not authorize a sale of the Software or anything created thereby. All intellectual property (including copyright, trademark and patent) in the Software is owned or controlled by Licensor and are protected by United States laws and international treaty provisions. Licensor retains all rights not expressly granted to you.
The Software may be used only on a single computer owned, leased, or otherwise controlled by you; or in the event of inoperability of that computer, on a backup computer selected by you. Neither concurrent use on two or more computers nor use on a local area network or other network is permitted…."
Edited by user Friday, November 21, 2014 2:44:37 PM(UTC)
Hm,
so Encore changed their policy since the 12th nov...
Jo
Jo
Jo
The ViaCAD licensing has been the same since the beginning of the program I believe it was 2005 or 2006. The difference in Punchcad products is the more expensive Shark programs allow for the multiple installs. Support was incorrectly grouping them all together. Shark programs have different licensing than ViaCAD programs and this has been consistant since the beginning. Sorry about the support confusion.
Well, I was lucky and used Black Friday to get me another english license... . I need it on a computer in the office and on my laptop and after all it's not that pricy . Though if I had been informed correctly from the start, I might have gone for the Shark LT version. Jo
