jaredlk
#1 Posted : Friday, November 21, 2014 1:21:11 PM(UTC)
jaredlk
Basically in the past i have been able to open .dwg files. but when i try to open this one it starts open/converting and about halfway through the program crashes. Is there something i am doing wrong? or is there another program i can use to convert the .dwg files and then open them???
Jared Kropf
NW Ag
#2 Posted : Friday, November 21, 2014 2:06:43 PM(UTC)
Can you send me the dwg file?
jaredlk
#3 Posted : Friday, November 21, 2014 2:20:58 PM(UTC)
jaredlk
here it is
91-9005_1-r2000.dwg (1,096kb) downloaded 7 time(s).
Jared Kropf
NW Ag
#4 Posted : Friday, November 21, 2014 2:48:53 PM(UTC)
I can read that dwg into the latest code stream. What product and version are you using?
Edited by user Friday, November 21, 2014 2:50:23 PM(UTC)  | Reason: Not specified
dwg.vcp (1,698kb) downloaded 1 time(s).
jaredlk
#5 Posted : Friday, November 21, 2014 4:09:12 PM(UTC)
jaredlk
I'm using ViaCAD 2D/3D version 8.0
Jared Kropf
NW Ag
#6 Posted : Friday, November 21, 2014 4:17:08 PM(UTC)
I'm able to open the file on ViaCAD 2D3D 8 build 1016 (Mac). If you are on an older version are you able to get an update using Help: Current Version?
jaredlk
#7 Posted : Friday, November 21, 2014 4:32:52 PM(UTC)
jaredlk
I am using build 1016 also on Windows
Jared Kropf
NW Ag
