Basically in the past i have been able to open .dwg files. but when i try to open this one it starts open/converting and about halfway through the program crashes. Is there something i am doing wrong? or is there another program i can use to convert the .dwg files and then open them???
Jared Kropf NW Ag
Can you send me the dwg file? Tim
here it is
91-9005_1-r2000.dwg
(1,096kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Jared Kropf NW Ag
I can read that dwg into the latest code stream. What product and version are you using?
Edited by user Friday, November 21, 2014 2:50:23 PM(UTC)
dwg.vcp
(1,698kb) downloaded 1 time(s). Tim Olson attached the following image(s):
(259kb) downloaded 14 time(s). You cannot view/download attachments. Try to login or register.
I'm using ViaCAD 2D/3D version 8.0
Jared Kropf NW Ag
I'm able to open the file on ViaCAD 2D3D 8 build 1016 (Mac). If you are on an older version are you able to get an update using Help: Current Version? Tim
I am using build 1016 also on Windows
Jared Kropf NW Ag
