Hi
I'm running a Viacad 2D-3D V8.0.0 Build 984 on a HP xw4600 workstation / Windows XP / NVIDIA Quadro FX 370 graphic processor
I've this bugg :
When I open the attached files separately, all is correct but if I open one, then import (viacad) the other file to mix them both , there is a change on the display : all things becomes dark and the Phong shade rendering is disabled.
See the files and image attached.
Michel
ImpBugg.zip
(1,616kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
Hi Michel This repeats for me as well. It has something to do with merging layers and ambient lights (possibly imported from DXF/DWG). Still checking into.. Tim
Hi Tim thanks for your answer my files were built from viacad without any import from dxf or dwg files. I had previously the problem sometimes when importing dxf or dwg so I stopped to do that. It may have something to do with complex shapes when they are merged. Hope you will find something to fix that. Michel
