Model to Sheet Problems
Hello, I am a newbie to ViaCad. I am currently doing a free trial of ViaCad Pro. I have created a few 3d models and when I do model to sheet it only comes out in one view. I have messed around with scale and everything that can be checked, and still only top view. I pulled up a 3d model from the example files and I have the same problem. I must be doing something wrong, or I thought maybe some features are turned off in trial mode. Thanks
In the model to sheet dialog box, there is a pull down option for Layouts. The default layout is for one draw view in top. All the other options are four views.
(73kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Thanks Tim, That seemed to do the trick.
