hmmueller
#1 Posted : Saturday, September 27, 2014 2:07:28 AM(UTC)
hmmueller
Hi - I'm still evaluating, and I noticed the following:
In my trial version (9.0.0, Build1104), "Select by partial object extents" does not work as advertised in a tutorial, namely that selecting from the right would select objects only partially covered by the selection rectangle - rather, I can only set a preference:
UserPostedImage
Also, partial selection seems not to work correctly (at least for my intuition): I have drawn a set of parallel lines. Now, when I draw a "fencing rectangle" without covering the endpoints, all is fine - the 5 lines get selected:
UserPostedImage
But when I start the rectangle somewhat more to the left so that it covers the endpoints, the lines are not selected:
UserPostedImage
This is (a little) cumbersome when the lines do not have a common overlapping segment, like here:
UserPostedImage
... but of course, shift-select helps then ...
Harald M.
Edited by user Saturday, September 27, 2014 2:08:21 AM(UTC)  | Reason: Not specified
#2 Posted : Saturday, September 27, 2014 4:52:58 AM(UTC)
hi,
maybe this could be a bug?
but anyway, i for myself mostly use "entire object extents" setting in preferences and do select lines (or objects) by fences. a fence from left to right only selects an entire covered object, a fence from right to left will access all touched objects.
note: the "show points" command for your objects should not be active. try to hide your endpoints and look if selecting objects would be easier
Edited by user Saturday, September 27, 2014 4:57:01 AM(UTC)  | Reason: Not specified
thanks 1 user thanked Guest for this useful post.
hmmueller on 9/27/2014(UTC)
hmmueller
#3 Posted : Saturday, September 27, 2014 5:17:03 AM(UTC)
hmmueller
Problem solved! - Switching off "Show Points" for all objects leads exactly to the expected behavior - thank you, I wouldn't have guessed that.
Best regards
Harald M.
#4 Posted : Saturday, September 27, 2014 12:56:19 PM(UTC)
Hello Harald
I'm looking into further...
