martinwh99
#1 Posted : Tuesday, September 9, 2014 1:31:09 AM(UTC)
martinwh99
Switzerland
Hello
I try to drag and drop a wood item from the render lib window to a 3D part. But this is not working. It worked in vers 8. What am i doing wrong?
Win 7/8 ViaCat Pro 9 build1108
regards
Martin
Martin Krueger
ViaCAD Pro V12 PowerPacked, Cut2D, Cut3D
rokoko
#2 Posted : Tuesday, September 9, 2014 3:18:47 AM(UTC)
rokoko
hi,
i think you need to render the whole object, otherwise the material is not visible.
the functionality may have changed
martinwh99
#3 Posted : Wednesday, September 10, 2014 12:34:22 AM(UTC)
martinwh99
Switzerland
How do it do that? What i'm doing is select a wood part and drag it to the object which is selected.
Martin Krueger
rokoko
#4 Posted : Wednesday, September 10, 2014 3:22:23 AM(UTC)
rokoko
hi, after dragging a material to the object, go to menu window -> photo render to open rendering tools. choose first render tool and click in your drawing window
hth
martinwh99
#5 Posted : Thursday, September 11, 2014 4:33:31 AM(UTC)
martinwh99
Switzerland
I will try thanks
Martin Krueger
