#1 Posted : Monday, July 18, 2011 5:27:16 PM(UTC)
Was thanked: 102 time(s) in 66 post(s)
Mirror, linked may have been discussed previously, but....
Mirror, Linked is awesome. I just learned of it today during lunch. As with the regular mirror tool, click the tool, select the objects to be mirrored (or, vice versa), pick an axis, select the mirror point, and make any post-action inputs.
I used to use the Ctrl key to make a copy of the source side. Now, I just use mirrored linked so that moving one part moves its sibbling part. This may or may not be ideal in some situations, but where symmetrical work is important, this is neat. Deselecting the "copy" function check box frees up my left hand from the Ctrl key.
I haven't yet tested to see if moving points along the way axis mirrors those changes to the mirror, linked side. Sounds like it will, but i need to see for myself.
phil
#2 Posted : Monday, July 18, 2011 7:02:09 PM(UTC)
phil
It's a great feature and the mirrored item will also auto-update itself when we modify the original side. I use it quite often. If we pick something and cannot modify it via the Inspector/entry box, that's because it's the reflected side/item... must modify the other/original side (unless we first break/remove the link).
Be sure to always save the document before we mirror anything and then it'll behave well and doesn't crash on us :)
misterrogers
#3 Posted : Tuesday, July 19, 2011 6:41:07 AM(UTC)
misterrogers
I concur. I've found that using the mirror-link tool in conjunction with constraints works wonders! Quite powerful indeed.
lebeau
#4 Posted : Thursday, July 21, 2011 12:59:58 PM(UTC)
lebeau
I love this tool too. I have experienced a lot of crashes when joining the mirrored part to it's parent though. I try to remember to make an instance of the parent part and performing a union on that part. Would be nice if there was a warning compared to a crash.
Mark
#5 Posted : Thursday, July 21, 2011 4:33:03 PM(UTC)
If you come across an example file that would be great. Just send to my email address.
BridgeCityMike
#6 Posted : Tuesday, July 26, 2011 11:27:15 AM(UTC)
BridgeCityMike
How is this tool any different from making an Instance and flipping that? I don't see the advantage of having a completely new tool.
#7 Posted : Wednesday, July 27, 2011 4:51:16 PM(UTC)
When i can get back into my CAD disk (I'm currently updating PCLinuxOS on my laptop and the new disk is in it), I'll check. IIRC, you may find differences if you right click on a parent and r/c on a mirrored part. One will be minus a data tab. So, you may not be able to thicken/rethicken/thin a solid. Mirror might act as a copy and do the same thing. I'll look closer later and either confirm or debunk my statement I'm making here (unless someone beats me TO me, hehehe...)
