ViaCAD 2D/3D Patch 737 - Display Problems (#840)
today i installed the ViaCAD 2D/3D Patch 737 and now i have some strange display problems. It seems that the "Object Info"-Dialog causes this problem. If the dialog is visible "Shade Now" does not work. Please take a look at the attached screenshots.
(there were no problems with version 711)
Anyone else with this problem?
My System:
Win XP Pro SP2
GeForce 4200ti, Driver Version 93.71
2GB RAM
Erich
erich_k4 attached the following image(s):
(30kb) downloaded 3  time(s). You cannot  view/download attachments. Try to login or register.
                On which OS are you seeing this problem. I have tested this on Both XP and Vista and have not seen this issue.  We suggest you check your video drivers and make sure they are up to date. If they are not, update them directly through the manufacturers web site
    Todd Q  CAD Support Specialist   Encore Software/ IMSI Design
