Can someone help. This is what happens when I create anything in sharkFX.
I have reset the PRAM, and repaired the disk permissions, and Re-installed the program.
This also happens when I open a file. everything looks like it is a mesh.
OS X 10.6.4
MacbookPro
Nvidia Geforce 8600 M GT
[COLOR="DarkRed"]** Problem Solved - I just deleated all the preferences. I don't know what caused it **[/COLOR]
Remmi attached the following image(s):
(147kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi Remmi,
It is due to ISO lines U & V preferences with a high number.
(115kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
That was the first thing I checked when this happened... but that was not the problem. I could not even open files. I eventually deleated the Preferences, and reinstalled. That was the only way to fix the problem... everything is working fine now.
