Why can't I blend these two solids?
wingnut attached the following image(s):
(54kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: wingnut Why can't I blend these two solids?
Hi
What happens when you try? Does it give an error message?
Yes here it is.
(51kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Did you try in blend options uncheck chained edges and check feature interaction box? And are you holding shift and selecting the faces of the two objects? Regards Jason
Yes, tried everything. Is this blend to sophisticated for ViaCad Pro 6?
I don't know, could you post the file of those 2 parts? Regards Jason
Not sure I know how to do this but I'll try.
Camero.vcp
(488kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 2 times Was thanked: 29 time(s) in 21 post(s)
I can blend for .020" and less.... No more because you don't have a continuity in your profile.
http://screencast.com/t/NGQ0ZWJl METEORE DESIGN / KEKO Stand Jean-Francois Jacques, Industrial Designer SharkCad Pro V14 B1653 Platform macOS 14 Sonoma
