willc2
#1 Posted : Thursday, March 3, 2011 11:10:01 AM(UTC)
willc2
I can't grab this window to move it because it's drag bar is "under" the system menu bar.
Does anyone know how I can:
1. grab and move the window
2. keep this from happening again
willc2 attached the following image(s):
stuck draft window.png (86kb) downloaded 5 time(s).
#2 Posted : Thursday, March 3, 2011 5:09:19 PM(UTC)
Mexico
Strange, i can not manage to put the palette under the menu bar, this is the way that appear after you select the draft angle command on the menu?
if you didn't already try prove this: press esc and open the analysis palette again
change your resolution display.
Luis G.
MacOSX Sequoia 15.7.7
willc2
#3 Posted : Thursday, March 3, 2011 5:54:01 PM(UTC)
willc2
I noticed that my second monitor was very slightly higher than my main display. Once I moved the arrangement down slightly and restarted ViaCAD, a tiny bit of the window drag bar was visible. Then I was able to move to a better spot.
Thanks to Luis G.
monitor arrangement.png (60kb) downloaded 5 time(s).
