2D Drafting
Opposite Point Circle starting point moves (#2226)
                Draw a straight line, and then use Opposite Point Circle to snap its first point to an end of this line. Extend the circle to roughly the size you're after, and click to create the circle. Now change its diameter to the exact size you require, and you should see that its first point is no longer on the end of the line. It seems after initially creating the circle from its diameter, VC reverts to working from its centre point and radius, and when you change its size, this loses (the much needed) location of the first point. Does anyone agree that this behaviour needs changing, as I find it counter intuitive?
                IMHO I think the current behaviour is correct. Most CAD work this way from my knowledge...you may need Shark in order to apply constraints and lock down certain points :p
                Hi Paul.
                Martin,
    Shark FX 9 build 1143
OS X 9.5
matter.cc
                The thing that makes characteristics like this problematic for me, is that when the circle is altered in size by a small amount, the intersection between curves becomes lost, but may not be apparent. It's when you start to do other things and discover the errors in the geometry that makes this sort of thing quite troublesome at times and time consuming to correct. Any chance of a comment from the management on this please, even if it's to say it can't be changed?
                Hi Martin,
                Or a tick box that says keep anchor point.
OS X 9.5
matter.cc
                Nick.
                Originally Posted by: blowlamp  Nick.
Here..here:)
2D Drafting
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
