Import/Export
DXF and Hatch Problem (#2206)
                Greetings All.
                Originally Posted by: blowlamp  Greetings All.
Hi, Martin
Yes the 5mm hatch spacing in the pic shows .196" in the object info box but the units are mm and the data bar shows 5mm spacing.
I can also get objects to move off the z axis when holding z key down.  X,Y are working aok, but z is jumping off at certain distances?
(25kb) downloaded 6  time(s). You cannot  view/download attachments. Try to login or register.
                Hi Jason and hopefully Tim.
Out of interest here is a couple of before and after export screen shots, that I should have included in my original post. Do you get this effect too?
I think there is a problem with the Z key in this respect, and also notice that the Z coordinates don't update on the information line at the top of the screen like the X and Y axes do, when moved with the mouse.
System is: ViaCAD v833 set up in metric units, and exporting to DXF in mm's. XP sp3.
Thanks.
Martin.
(181kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                >>Draw a circle or elipse etc, and apply a hatch pattern to it, then export as a >>DXF file. Import back into ViaCAD or other application, and you should find >>that the hatching is now separate from its boundary, a
                Originally Posted by: jdi000  Hi, Martin
Hi Jason,
  I don't know enough to debate with  you, but I couldn't help but notice that the image attached to your message shows the hatching to be "Scale = 0.196..."  in the object info box.  I do not understand how this "Scale" factor relates to the hatch; shouldn't it show the actual dimension of the hatch spacing, as your message suggests?  If not, to what basis is the scale factor referring?
Regards, Ian.
    Ian Kirby
                Originally Posted by: ianjkirby  Hi Jason,
HI, Ian
Yes the object info shows the hatch spacing but calls it scale, not sure Tim would have to comment why?
It was also displaying inches even when units were set for mm.  I had the hatch spacing at 5mm but it was showing in inches.  I guess scale in object info means spacing.
                Tim and Co.
                Tim.
                Originally Posted by: blowlamp  Tim.
Martin
Have not been able to figure out yet,  still looking.
                Tim.
Import/Export
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
