2D Drafting
Points Along Curve Bug (#2162)
While drawing a division plate, I came across this bug that choked my CAM system.
Using the Points Along Curve to create 100 point around a circle, each point is repeated many, many times. So much so, that my CAM system locked up solid. The points list displayed at around 10,000 instead of 100.
Please see Attachment.
Thanks.
Martin
divplate.vc3
(1,551kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
I wonder if it's a problem in the export .. as when I made a circle and dropped 100 points along it - I got an object count of 101
Thanks: 93 times Was thanked: 103 time(s) in 66 post(s)
Is it possible that the center of the circle is being counted as one or 101?
Right, I've just checked again and it didn't do it at first. It is repeatable if the initial point count is edited to a [COLOR="Black"]higher[/COLOR] value while the points are still highlighted. Thanks for looking. Martin.
Martin Repeated here as well. Fixed in the next build(832). Tim
2D Drafting
