lazer
#1 Posted : Monday, August 31, 2009 11:51:37 AM(UTC)
lazer
Hi Tim
When designing an entity "Interpolate Spline" and export for DXF-R12, lack a subroutine in:
POLYLINE VERTEX 42, see the internal structure of the DXF.
ENTITIES
0
POLYLINE
8
name of layer
66
1
10 #.#
20 #.#
30 70
1
0
VERTEX
8
name of layer
10 #.#
20 #.#
30 #.#
42 #.###
The bulge is the tangent of 1/4 the included angle for an arc segment, made negative
if the arc goes clockwise from the start point to the endpoint;
a bulge of 0 indicates a straight segment, and a bulge of 1 is a semicircle.
For a subroutine equation is: bulge= tan(sweepangle/4)
See in http://www.afralisp.net/lisp/Bulges1.htm
Regards,
Armando
#2 Posted : Monday, August 31, 2009 9:37:44 PM(UTC)
Hi Armando,
Since R12 does not support a Spline entity, we dump out the spline as a polyline.
We use the OpenDesign DWG tool kit for DXF & DWG files which automatically converts the entity type into the DXF/DWG attributes you end up seeing in the ASCII DXF file.
Are you unable to read this file into another package?
lazer
#3 Posted : Tuesday, September 1, 2009 10:46:27 AM(UTC)
lazer
Hi Tim
Other versions of DXF are OK.
The CamBam open any version DXF.
In DXF-R12 the ViaCAD converts "Interpolate Spline" in polyline, lack "bulge".
See http://www.relief.hu/h_dxf12.html
Cheers
Armando
lazer attached the following image(s):
