blowlamp
#1 Posted : Thursday, July 14, 2011 4:29:55 PM(UTC)
blowlamp
Someone on another website posed the problem of how to 'tangent fit' an ellipse into a parallelogram, so I thought I'd give it a go with ViaCAD, using an example that was put forward by a chap there.
His technique was to differential scale a circle into an ellipse, but it doesn't seem to be something that can be done as easily as it should be for us.
I've included a video to try and show how the behaviour of the Scale tool varies when used on curves compared to surfaces.
In short, I would have liked to scale one axis of the circle along the orientation path of the Gripper/Workplane, .
Martin.
http://screencast.com/t/9sJzWOAsV
billbedford
#2 Posted : Friday, July 15, 2011 1:18:55 AM(UTC)
billbedford
Can't you just turn off 'uniform scaling' in the gripper inspector?
blowlamp
#3 Posted : Friday, July 15, 2011 1:37:57 AM(UTC)
blowlamp
It is turned off in the video. The problem is that curves aren't scaled to align with the workplane/Gripper when is either is rotated.
Martin.
billbedford
#4 Posted : Saturday, July 16, 2011 2:12:42 AM(UTC)
billbedford
The gripper works as expect as soon as it s realised that the circle is a special case of a circular arc, i.e. it has start and end points.
[ATTACH]3943[/ATTACH]
Screen Recording.mov (750kb) downloaded 0 time(s).
#5 Posted : Monday, July 18, 2011 3:57:25 PM(UTC)
>>In short, I would have liked to scale one axis of the circle along the >>orientation path of the Gripper/Workplane, .
Martin, thanks for the heads up. Fixed.
blowlamp
#6 Posted : Tuesday, July 19, 2011 10:39:33 AM(UTC)
blowlamp
Thanks for sorting it out, Tim - it's much appreciated.
Martin.
